Technical Cigarette Lighter not working
The fuse for the cigarette lighter is where the ECU is - slightly to the right of the steering wheel. You can open this up using a 2p coin on the mahoooosive screw holes. Will be a grey tool clipped to a holder - use this to take out the 20Amp, yellow fuse (far right fuse on second to last row). Details for where all the fuses are can be found in your car manual and also in the haynes manual - as you know I have made a thread with a link to download this :)
You can check the resistance across it. Compare to a known working fuse of the same current rating is the simple way to be sure.
