Hi Guys.
new to the forum.
Wife has an X reg Punto Mk2
It has developed the power steering fault. (no power)
Have read on of the guides on here that suggests it could be one of the relays in the motor and how to replace them.
however on doing further research i cam across a video on you tube that shows a possible Temp Fix, by removing the 60 Amp fuse in the engine fuse box, then starting the car, leave to run then replace the 60 Amp fuse whilst run, and the fault has gone.
Tried it with mine and the fault has gone..
Does anyone know what this does??? the guy on the video suggests its the EPS fuse, but has this got something to do with the ECU??
Suggestions gratefully appreciated.
Regards
Lee.
new to the forum.
Regards
Lee.
