| Thread Tools |
![]() | #1 | ||
Posts: 146 Thanks: 4 Trader Rating: 0 ![]() | Braking issues! I'm hoping you guys may be able to help me out, had a very strange brake failure this week, there was a popping feel under my foot while braking and the pedal then went straight to the floor, as i drifted into what was a luckily empty roundabout! The strange thing is that the brakes seem to be working fine now any ideas? I'll be getting it checked out but just thought i'd see if anyone had experienced anything similar? Or maybe had an idea of what may have caused it? I'd understand if they had completely gone but the fact they appear to be working again is a little worrying.
![]() | #2 | ||
Posts: 3,018 Thanks: 217 Trader Rating: 0 ![]() | Re: Braking issues! I would be worried too. Check for leaks at all wheels, master cylinder and check fluid level.Has the system been worked on lately and maybe not bled correctly? Check that the pads or shoes are not dragging which can boil the fluid especially if it hasn't been changed in a while. Saw a car where the handbrake had been left on ever so slightly and after 10 miles the pedal went to the floor. When the driver recovered from the shock they had cooled enough to function normally again.
![]() | #3 | ||
Posts: 146 Thanks: 4 Trader Rating: 0 ![]() | Re: Braking issues! well that's the weird thing, it was maybe only a mile into the trip and they seem to be functioning fine again, I'd assume that had there been a leak that caused it they would't be working again, I'm definitely taking it to the garage Monday morning, just wanted to check whether there were any obvious causes i maybe was unaware of.
![]() | #4 | ||
Posts: 3,018 Thanks: 217 Trader Rating: 0 ![]() | Re: Braking issues! Wise move - Live long and Prosper. On the way to the garage, drive as if you don't have any brakes.
![]() | #5 | ||
Posts: 146 Thanks: 4 Trader Rating: 0 ![]() | Re: Braking issues! Haha! Luckily for me my garage is about 100 metres away, I'll be travelling slowly enough that should they fail i can open the door and use my feet to stop the car!
![]() | #6 |
![]() | Re: Braking issues! I would hazard a guess your car has ABS?
__________________ Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers can’t be wrong ![]() And now the owner of a shiny new PuntoHowTo Drivetribe |
![]() | #7 | ||
Posts: 146 Thanks: 4 Trader Rating: 0 ![]() | Re: Braking issues! No, it's a poverty spec MIA ain't got nothing as luxurious as ABS ![]()
![]() | #8 | ||
![]() | #9 | ||
Posts: 146 Thanks: 4 Trader Rating: 0 ![]() | Re: Braking issues! My floorpan isn't quite that bad, yet!
![]() | #10 | ||
Posts: 7,584 Thanks: 542 Trader Rating: 0 ![]() | Re: Braking issues! I would be worried too. Check for leaks at all wheels, master cylinder and check fluid level.Has the system been worked on lately and maybe not bled correctly? Check that the pads or shoes are not dragging which can boil the fluid especially if it hasn't been changed in a while. Saw a car where the handbrake had been left on ever so slightly and after 10 miles the pedal went to the floor. When the driver recovered from the shock they had cooled enough to function normally again. its usually a sticky rear drum as brendan says,not nice at all especially when you come up a motorway slipway, ever since i always dab my brakes when in unknown cars well in time to confirm everything is there
![]() | #11 | ||
Posts: 146 Thanks: 4 Trader Rating: 0 ![]() | Re: Braking issues! Well that's good to hear, hopefully not too expensive to fix. One of the scariest moments I've had on the road!
![]() | #12 |
Posts: 685 Thanks: 3 Trader Rating: 0 ![]() | Re: Braking issues! had that happen when driving my mothers car before the line from master cylinder under the bonnet was perrished and split the brakes on a punto use the same fluid as the clutch so i'd be looking at the master cylinder for clutch and brakes
__________________ Car : Fiat Stilo Active 1.6 16V Mods : full straight through and decat exhaust, HID and LED upgrade, Full 10% tint and 16" sunstrip, Pink hid headlights and 6k foglights |
![]() | #13 | ||
Posts: 146 Thanks: 4 Trader Rating: 0 ![]() | Re: Braking issues! Like I said, the braking went but seems to be back. I assume that with a leak or a split the brakes would just be completely gone? That's what's so odd about the whole thing.
![]() | #14 | ||
Posts: 7,584 Thanks: 542 Trader Rating: 0 ![]() | Re: Braking issues! and if you had a fluid leak the handbrake light on the dash would be permanently illuminated
![]() | #15 | ||
Posts: 3,018 Thanks: 217 Trader Rating: 0 ![]() | Re: Braking issues! You would think so. Makes perfect sense. But I did once come across a rear slave cylinder that seemed to hold up to a point but above that pressure the pedal sank slowly to the floor. Very rare I would say and a fairly obvious leak at the wheel.
Thread Tools | |
![]() | andystew | Scudo | 3 | 09-07-2018 13:56 |
![]() | tommy_8884 | Grande Punto | 20 | 06-03-2010 18:20 |
![]() | mrcinquecento | Punto (Mk2/2b) | 2 | 20-01-2009 10:05 |
![]() | fenton_jd | Punto (Mk2/2b) | 5 | 25-06-2007 22:59 |
![]() | arc | Cinquecento / Seicento | 2 | 04-09-2006 13:59 |
