Old 26-05-2012   #1
Front Electric Window Not Working
I have a 2000 Punto with a front driver's side electric window that won't open. When you use the window switch you can hear a clicking sound in the driver's door (a relay?).
I have done the following so far:
  • I have checked the fuses are OK.
  • I have removed the door panelling and tested the plug that goes into the window motor assembly. When the window switch is pressed, 12 volts appear on the plug - both the up and down voltages appear to be OK.
So my next step is to take out and inspect the window motor / regulator. This is where I am in a catch-22 situation. Using the Haynes manual it says to to remove the regulator you have to separate the window glass from the regulator. To do this you have to operate the window regulator mechanism (which isn't working ) so that the glass-to-regulator retaining clip is visible through the door aperture.
I can't believe that this is a unique problem and am hoping someone can offer me some guidance on how to remove the regulator
logit is offline Reply With Quote Quote
Old 26-05-2012   #2
Trader Rating: 10
dave has donated!
Re: Front Electric Window Not Working
if you unbolt it it will drop low enough to get the clip off the middle of bottom of window, careful as the clip is plastic and break easy.
you could just put power to motor first to see if it works
Likes logit liked this post
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 27-05-2012   #3
Quote Originally Posted by dave View Post
Thanks for the tip. I applied power to the motor and nothing happened. I assume from this that the regulator needs replacing. So I will obtain a new one before taking the old one out. Thanks again for your help
Old 27-05-2012   #4
Trader Rating: 10
dave has donated!
new motors complete in classifieds https://www.fiatforum.com/classifieds
Old 27-05-2012   #5
Burkina Faso (Upper Volta)
cable might be fubbered
i would ascertain before i purchased a motor
cant find the motor in the link but these cable cassettes are easy to change as a unit anyway
s and b is offline Reply With Quote Quote
(T) Stilo electric window not working properly leechartlon Stilo 3 11-04-2010 21:06
(G) Electric Window (Drivers Side) not working Colin. Punto (Mk2/2b) 2 21-06-2008 13:21
(T) Electric Window Relay not working. MidnightBlue60SX Punto (Mk2/2b) 3 28-05-2008 07:25
(T) electric window not working leaky Punto (Mk2/2b) 1 07-09-2007 08:38
(T) Electric N/S window not working jep73 Bravo / Brava 5 21-09-2006 21:54
