Technical Red hot brake discs
nawtwrong
United Kingdom.
I've just replaced the front brake discs on my Mk2 Punto 8V 1.2.
After fitting the new discs and putting the pads back in the callipers, I heard a bit of friction between the pads and the discs when I turned the wheel (before I lowered it to the ground).
I've been out in the car today for 10 mins, tested the brakes, they work fine but the discs were absolutely red hot when I got back.
Is it normal for the pads to rub slightly against the discs when driving?
I reckon this is causing them to get hot while I'm driving.
Cheers for ur help!!
Your disks will always get hot - You can't stop that. It's part of the way they work. Your disk brakes work using friction, a by-product of friction is heat.
AFAIK, the pads and disks always rub together very slightly.
There's normally a little contact between pad and disc with the brakes off, this isn't enough to generate any noticeable heat though.
A lot of heat is generated when you actually brake though, and it takes the discs a while to cool down. Sounds like your brakes are fine to me.
gsbellew said:
Em, but red hot after normal driving?
Even on track days I didn't notice my brakes to glowing red after a run :confused:
drive harder ;)
the pic is from a 1l corsa, but we did the same with a 1.2 8v punto :D
You say you tested the brakes for 10 minutes, so obviously they'll get hot then, but how long did you drive for without heavy braking? I think it can take quite a while for the disks to cool back down, especially if you're not moving. The only times I've had red-hot disks are when:
The rear brake was binding slightly. This squealed a lot too.
A session of "spirited" driving down some back lanes. I actually got the pads smoking quite heavily :D
Try again, and drive for a decent period with as little braking as possible, possibly even doing the final stop on the handbrake. Then see how how they are.
H
arc said:
drive harder ;)
Ahhh right, I suppose the solid disc wouldn't help in comparison to my vented ones, and seeing as I can barely see the brakes I suppose I don't know what could be going on behind the wheels really, still though, for normal driving the brakes should not glowing.
