AmyDinsdale
I think my punto (1.2 2001) has had just about every problem. The other day the temperature gauge went to the top and the red light went on but when I kept going it went down and back to normal at the half way point, so I added some more water as it was just to say below the min point.
It has been doing it the last few days on and off and it judders when it starting along with white smoke out the exhaust and when I checked the water today it was basically empty again. While I was there I checked my plugs as a mate told me to check for rust and this is when I discovered someone had put the leads on wrong, I changed them to be correct but 3 of the 4 plugs already looked sooty.
Once changed the car seemed to run a tad smoother and juddering less but the temperature problem is still there. I'm guessing it's my head gasket but i'm just wondering if it could be anything else before I go through the hassle of replacing it.
