Old 01-05-2005   #1
Radiator cooling fan not running
Hi everyone.
Got a bit of a problem. Punto SX60. 1998. . I've noticed that in slow traffic the temp shoots up only to go down when on the move. Did a bit of investigating and noticed the fan isn't cutting in. Has anyone got any ideas of common problems? Any wiring details would be gratefully accepted.
Thanks in advance.
TonyTantrum is offline Reply With Quote Quote
Old 01-05-2005   #2
thefishdude has donated!
Balloony Champion, Bee Wars Champion, Submarine Champion
Re: Radiator cooling fan not running
fuse for the fan may have gone, the censor that turns the fan on may have gone. or the fan is bust.
out of them 3 i would say most likely is the switch that turns the fan on . im sure there is way to test but i cant remember it at the mo. im sure someone iwll know
2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm
thefishdude is offline Reply With Quote Quote
Old 01-05-2005   #3
Trader Rating: 10
dave has donated!
welcome to the forum
check fuse first, then if its ok, hot wire the fan if it works then its prouably the sensor switch.
“The further a society drifts from the truth, the more it will hate those that speak it.”
Old 02-05-2005   #4
Quote Originally Posted by TonyTantrum
Hi everyone.
Thanks in advance.
I dont like to be the bearer of bad news but this happened to mine and I foundout it was the head gasket, it had blown and wasnt cheap to fix . Hopefully im wrong and its just a fuse, just giving you a warning. Hope all goes well.
angel751 is offline Reply With Quote Quote
Old 02-05-2005   #5
KwikPhix328 has donated!
Whilst investigating the cause of my Heater/Ventilation fan not working a few months ago i discovered that it shares the same p/n and model of Relay as the radiator fan.
I substituted the radiator fan relay for the 'suspect' heater one and hey presto the Heater fan worked and the fault transposed over to the radiator fan, so i bought a new relay - problem solved. This proves that these components can 'go bad' .
I would also look into the Relay as part of your fault diagnosis for this problem. The relays are usually mounted on one of the fuse boxes , mine where both on the Engine bay fuse box IIRC.
Hope this helps.
Current car:Sedici 1.9 Dynamic - Diesel 4x4
Previously owned Fiats:Punto Mk2 1.2 8v ELX
Brava (facelift) 100SX
Brava 1.6 SX
Punto Mk1 75SX
KwikPhix328 is offline Reply With Quote Quote
(T) Cooling Fan Blows Fuse del mar Cinquecento / Seicento 2 04-04-2005 10:10
Radiator Fan Won't Work freds_spider Lets Talk FIAT 1 15-09-2004 08:47
(T) broke fan???? Grim_Evil Cinquecento / Seicento 8 06-09-2004 08:30
(T) Sodding Fan will not work! Sei-Mad Cinquecento / Seicento 12 05-09-2004 22:52
(T) Fan blows fuse after a while Orca Cinquecento / Seicento 7 13-06-2004 08:10
