Thread Tools
Old 02-04-2012   #1
Rear Drum Parking Brake
Hey guys,
Cars just failed its MOT for the hand brake not actioning on rear nearside wheel. I've had the drum apart for a look, everything seems OK, although I'm wondering....should the handbrake lever (the one in the drum) take its leverage from the hub or a different point, mine pushes against the hub to move the shoe out.
Cheers james
snapjim is offline Reply With Quote Quote
Old 02-04-2012   #2
Re: Rear Drum Parking Brake
have you checked the condition and adjustment of the cable? there is usually an adjustor on drum brakes as well.
finally check the amount of material left on the shoe and that nothing has fouled it causing it to not work properly like oil, brake fluid or anything thats leaked from the shocks
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 02-04-2012   #3
Yeah the cable seems good, I might just get new shoes and try those, I've taken off the other side to compare and nothing seems different. I'm more worried about the pivot point, the off side one doesn't seem to touch the hub, yet the near side does!!
Old 02-04-2012   #4
Sussed it, the slack adjusted was jammed on the near side wheel meaning the shoes had miles to move!!
Thread Tools
(T) Rear Brake Drum Corrosion jrkitching 500 11 19-05-2010 20:31
(T) Rear brake drum nut JonseyMJ07 Grande Punto 17 24-04-2010 21:27
(T) rear brake drum stuck Rotski Panda (Classic) 25 08-03-2010 11:22
(T) Rear Brake Drum overhaul SkinzCinqSporting Cinquecento / Seicento 33 01-05-2006 18:45
(T) Rear Brake drum Seizing Matt925 Cinquecento / Seicento 5 13-11-2005 23:41
