Cind3rella
- Feb 28, 2012
- 4
- 1
hi, i have a punto active 2004 1.3 and it is over fuelling. It was misfiring and had black smoke at the back. so we changed the coils, HT leads and the coolent temp sensor. most of the codes went off (there were about 5 codes previously) .we have two codes still on, coolent temp sensor and the inlet temp sensor?changed an injector and this made the mis firing considerably less. (i called an AA guy out he said it was over fuelling-hence the juddering) the garage tried to put a new ecu but he said it didnt work...i need help! i live in surrey and i heard that if i remapped the ecu this would help seeing as we changed the coolent sensor? oh and the fan comes on straight away all the time but it is not over heating!
i have noticed the temp gauge on the dashboard does not work- could this be causing it?how do i get this to work?we checked all the fuses...
any help would be much appreciated!!! im at my wits end-no one knows how to fix it
