![]() | #1 |
Posts: 36 Thanks: 0 Trader Rating: 0 ![]() | Horn Relay Reading this thread https://www.fiatforum.com/punto/2604...mk2-punto.html AM I right in thinking that the horn relay for a mk2 punto is 15amp? Do I need to think about anything else when buying a new relay? The old one vanished into thin air at some point in my cars history and I do like to have a working horn.. you know, road legal and all that. Cheers Ked
__________________ 2002 Fiat Punto 1.2l 8v Active in silver |
![]() | #2 | ||
Posts: 7,584 Thanks: 543 Trader Rating: 0 ![]() | Re: Horn Relay highly unlikely the horn relay went walkies its much more likely a horn fault or even a fault it the steering wheel squib wiring try giving horn a good clout as mate pushes button
![]() | #3 |
![]() | Re: Horn Relay Dunno what went walking............. If you have a horn that's not working, the fault will usually be on the earth side or the connectors. A good scratch and re-attach often works.
__________________ M12 fund £20 |
![]() | #4 | ||
![]() | #5 |
![]() | Re: Horn Relay If horn is not working and relay is still present..................
![]() | #6 |
Posts: 36 Thanks: 0 Trader Rating: 0 ![]() | Re: Horn Relay The horn works just fine if I put a relay in. I tried it with a 20amp relay from the position above in the engine fuse box, and it worked just fine. So, i just need a relay and its done. Next time I pop to breakers, I got a list of things I want. ![]()
![]() | Pfil32 | Ducato | 12 | 23-07-2015 12:07 |
![]() | marino | Cinquecento / Seicento | 8 | 16-08-2009 11:33 |
![]() | jacob25119 | 124 Spider (Classic) | 2 | 14-04-2008 03:50 |
![]() | dreamofgilgamesh | Punto (Mk2/2b) | 2 | 12-03-2007 13:19 |
![]() | Ilya | Uno | 2 | 22-11-2004 07:56 |
