Technical Punto fuses
huddsta
Hi guys
Went over a speed hump (sorry mountain) last night and as I did my CD player, cold cathode neons, clock, interior lights and fag all died. As these are all fed from a constant 12v source (correct me if I am wrong) has the fuse just gone?
If so, where is the fuse located? I've had a poke around but can't find it.
Its a 98 1.2 sporting
cheers
There is a black fuse box at the back of the engine bay, with 2 large fuses in, both of which are intact.
Right, sorted. Found all the internal fuses now, just to the right of the streering colum is the 'oddments' tray. If you undo the 2 screws at the top a compartment swings down with all the fuses behind it.
Job done
Don't know if you've already done it but if it helps it should be fuse no.10 in the box, which is a 10A
