Hi guys,
Its my second fault to ask for advice Good Ole Punto
Right so im driving along fine, I then cannot find 2nd Gear i pull over and i cannot find any gears at all. For some reason it would find 1st and 2nd some times, upon testing it would not go any higher then 2nd. Also it couldn't find reverse.
I then call the recovery man to pick me and my car up. We take it back home and we have a little look at it. We found the issue. This is where my Technical Car knowledge is rubbish. We could see what looked like Metal cables coming from the gearbox (One for my clutch, one for the gears?). The Cables closet to the ground had its black plastic clip like thing (Sorry for the bad terms) Snapped and was just not clipped onto anything. This was the letting this Cable loose and i assume causing my gearbox to find 1st and 2nd sometimes. looking at the other cable it was find and was not lose.
So my question is.......... Where do i buy a new plastic part for that cable ? and how much will it cost to buy and get it fixed?
Thanks guys Much appreciated,
Ben
Ben
