fiatpuntodriver
- May 7, 2011
- 19
- 5
Hi. I have 2001 X reg Punto HLX with a 1.2 16v petrol engine. The number 2 cylinder is not firing. I have tested the spark plugs and also moved the number two spark to another cylinder and vice versa. The number 2 still fails to fire. I then took each spark plug out int turn, fired the engine and held it next to the head. All but the number 2 produced a spark. Next, I tested all of the HT leads (1 & 2 around 14000 ohms and 3 & 4 around 13000 ohms). I then plugged the number one lead into the number two port on the coil and this one then did not work. At this point, I am thinking that it is not the leads or the plugs. So, I tested the coil circuits (I know that if it was the coil then two plugs would be down but I thought it was worth a shot). The primary circuits were both around 7000 ohms and the secondary circuits were both around 22000 ohms. Could it be the ECU not giving the firing command, or have I missed something easy? Has anyone got any ideas please?
