Old 05-12-2011   #1
changing the radio
I know how to get the standard radio out im just wondering if i'll be able to put my sony xplod which i had in my 106 straight in to it or will i need different connectors?
Punto Coombz is offline Reply With Quote Quote
Old 05-12-2011   #2
Trader Rating: 5
fingers99 has donated!
Re: changing the radio
Impossible to tell without knowing the Pug!
But, if no one has chopped anything off, Maplin or Halfords will come up with the right ISO connector lead to make it easy peasy.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 05-12-2011   #3
ok thanks man
Old 05-12-2011   #4
Burkina Faso (Upper Volta)
iso swap over cable i bought off the bay didnt work on puntos even though it was advertised as did a
i suggest let maplinhalfords confirm their lead will work and either try it in the par kark or get them to write it will on the receipt in case it doesnt
s and b is offline Reply With Quote Quote
Old 05-12-2011   #5
wilko1992 has donated!
It should plug stright in to the exicting connector for the standard radio but you may want to wire the red (on your xplod) to the ignition so it will turn on and off with the key, Ther is a couple of guides on how to do it
Quote Originally Posted by JustAndy View Post
The faster you go the louder it gets! Thats what i like haha
wilko1992 is offline Reply With Quote Quote
Old 05-12-2011   #6
I've just swapped my sony xplod out of my old Alfa into the punto mk2 (radio/tape deck)
1st .. don't buy the of the bay as stated like i did. The release pins were handy but the new facia was a very poor fit and took some extra work to get the side claws to snap in the 2 holes on the dash. iso leads were incorrect.
2nd .. After seeing i couldn't conect the cars harness to the sony, checked the xplod old box and in there was the correct wiring harness that i didn't need when fitting it to my Alfa. Just connect the male to female iso's and then the connector to back of your sony (you will need an antenna adaptor unless you use the one from your pug). I like to switch my unit off myself and not with the ignition so can't help you on that.
hope this helps.
muse2112 is offline Reply With Quote Quote
(T) Help changing Factory radio placidcasual 500 4 23-01-2011 18:41
(T) Changing radio RazRazor Doblo 2 05-12-2009 17:53
Changing factory radio - HELP! csteele100 I.C.E 1 23-08-2009 21:58
changing radio on GPS GPS I.C.E 2 20-01-2008 12:30
