Old 21-11-2011   #1
Trader Rating: 1
Mk2 1.2 16v Exhaust Manifold/CAT
Can anyone tell me if they know of 2 type of manifold for this car? The one on my car has two lamba sensors, one pre and post CAT; but I think I may have seen a version with one lamba sensor for the same type of car.
My ebay items: http://search.ebay.co.uk/_W0QQfgtpZ1...Zpeaster2kQ5f1
peaster2k is offline Reply With Quote Quote
Old 21-11-2011   #2
Trader Rating: 5
fingers99 has donated!
Re: Mk2 1.2 16v Exhaust Manifold/CAT
I think some of the early ones came with 1 lambda, hence 1 boss.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 21-11-2011   #3
Burkina Faso (Upper Volta)
usually up to y reg only have one lambda hole
of course you can always buy the captive nut from an exhaust supplier to stick in yours or chop it out of your failed one and weld it in
main thing is to make sure the replacement s/h manicat doesnt rattle when shook which will suggest its flubbered
s and b is offline Reply With Quote Quote
Old 21-11-2011   #4
Trader Rating: 5
Why are you asking, anyway?
M12 fund 20
Old 21-11-2011   #5
Trader Rating: 1
Looking to get a replacement one as mine is blowing as has a crack in the manifold and alone the weld between the manifold and CAT.
Old 22-11-2011   #6
Trader Rating: 1
Quote Originally Posted by s and b View Post
Thats what I am thinking of doing, does anyone know the size of the nut the sensor goes into?
Old 22-11-2011   #7
Trader Rating: 5
They're usually 18mm (at a guess 1.5 pitch). An oil drain plug?
If disregarding the second lambda, it's usually advised to wrap it in silver foil.
M12 fund 20
(G) Cost of a manifold Cat convert 1.2 16v Punto rushdentillidie Punto (Mk2/2b) 1 24-07-2010 13:30
(T) Punto mk2 Sporting 16v 1.2 exhaust cat manifold & engine mounts wanted sibberz100 Punto (Mk2/2b) 1 26-12-2007 15:02
(T) SPI manifold, cat and exhaust on an MPI paulbfd Cinquecento / Seicento 12 22-04-2006 09:02
