My Wife's 04 Punto has just suddenly started blowing ridiculously loud - the noise is deafening and sounds like a Spitfire!
We replaced the front section of the exhaust about 3 months back due to corrosion - worked fine since then.
Suddenly today she got about half a mile from our house and this started.
When she pulled over and put it in neutral the revs were peaking to about 2k, then the engine would almost die, then back up - on an endless cycle about once every two seconds.
The noise is so loud it is almost impossible to pinpoint where it is coming from Definitely from within the engine bay rather than further back as with the exhaust - it sounds like from the top of the engine - rather than the base - but given the volume when you go anywhere near it it's almost impossible to determine.
Any initial thoughts/suggestions?
My primary concern is - safe to drive home? About a mile or so.
