dumbledore
Member
- Jul 4, 2010
- 745
- 144
I started experimenting with lowering my punto from the start I bought it. Standard springs roll far too much. Although the car can handle it and you can push it hard with some practice, you always feel is going to roll over. I experimented with some springs but now have settled to 35mm lowering springs, standard new shocks and tyres. The handling is now the best compromise for my type of driving. I can through it in corners with no worries. The suspension is still compliant and it can handle reasonably bad road surfaces without having to slow down. Obviously the car is more nervous on bad road surface but this is a compromise I accept. Also high speed motorway driving feels more secure then standard suspension setup, but the ride is more nervous and is upset bad road surface. Moving any lower will need coilover setup but will make the ride even harder with no more advantages in handling. Adding wider tyres will improve handling but there is no power so basically a pointless exercise unless you are looking for looks.
