General 04 Plate Cold Start Issue
ronxray
Nuneaton
Chilly morning last week car would just about turn over.
Jump started, ran for a couple of minutes, then started OK.
Leave for 3 hours same problem.
Changed battery for new one, all OK for a couple of days, then from cold first turn of key laboured and would not start, second turn of key all OK.
Battery voltage around 12.5 volts, with engine running around 14 volts.
Could very sluggy (thick) engine oil be the issue?
Any better ideas please!!
Regards
If engine oil is that thick and sludgy its well past replacing
Get the engine toasty hot - add a chemical cleaner if you like - drop it replace filter and replace oil
Or
engine Hot - drop Oil
Fill with Cheap Asda Oil with a Chemical Flush
Run the engine till its had time to circulate properly
Drop the Oil again
Replace filter and refill with good clean oil :)
When Starting - is it struggling to turn over that badly?
poor turning over could be earthing
Get a Negative Jump lead - Clip one end onto the Engine Mount or the Bonnet Catch - and the other end on the Negative pole of the battery
try starting then - if it starts with ease - its an earthing issue on the Starter motor via the body earth
Also use a multi-meter and see how much of a drain you have
Ziggy
Thanks for your response.
The car belongs to my daughter, and she has not changed oil for ages, tut.
Checked for bad earth ((I'm an electronic tech).
Why I'm looking at the oil is because she said first time this morning engine just about turned over, the second time it turned normally and started.
I have since checked oil level which was low, so I have added a litre of "thin" general purpose engine oil.
I will now have to wait until tomorrow morning.
I put the oil in to thin what was in the sump.
Started this morning first time.
I find it hard to believe "thick" oil could cause the issue, but maybe it did.
Now will flush the system and see how it goes.
Regards
