Hi, got a gearbox problem, I suspect differential bearings collapsing as every time you take the foot off the accelerator it makes a noise like gears rubbing against the casing and a vibration is felt through the gearstick, most similar noise I can think of is if you shove a piece of card thru bicycle spokes and cycle.
Sound goes when depressing the clutch, so sounds like a diff bearing problem.
Is it expensive or a difficult job to do the differential bearings? Any preloads need setting up and shimming? I know on most gearboxes it is a strip down but read somewhere diff is removable? Or is that a different box. Obviously can't drive it around much more without doing serious damage lol
