- Apr 8, 2008
- 16,742
- 3,186
Which way around is for bleeding the brakes and clutch?
I heard somewhere that you start with the Furthest away from the Brake Cylinder - So since mines Front driver Side i Start with the
Rear Passenger
Then Rear Driver
Passenger Front
Driver Front
is that correct?
- also how do you bleed the Clutch - should there be a bleed valve on the slave cylinder To bleed the clutch
As i've lost all my fluid Its no fun - Got a bleeder kit tho
Ziggy
Rear Passenger
Then Rear Driver
Passenger Front
Driver Front
is that correct?
Ziggy
