gavinreadman
- Sep 16, 2011
- 14
- 5
Hi new to the forums currently have a few fiats in stock
one being a Punto 1242cc on a 2000 (v)
took the car in part ex yesterday diddn't bother to check oil or water as it it just a cheapie!! Used the car all day yesterday as it has a bit of tax and mot and fairly cheap to run around in had no problems apart from a slight missfire if i tried to pull away from junctions in 2nd while still rolling!! this seemed to clear as it reached norm temp. so i thought nothing of it. temp guage between 1/4 and 1/2 all day!
Today got in the car this morning (horrible day very damp) had the same problem with the missfire when cold, just put it down to a bit of damp on a lead?, However 5 mile into my journey temp guage went up to 3/4 and was going up and down like a yoyo between 1/2 and 3/4
decided to pull over and check the engine!! seemed fine to me (i have a fair bit of mechanical knowlege) slowly took water cap off could see water! result just put it down to a dodgy guage and kept going!! (big mistake)......also must add the heaters worked fine!!
got to my destination fine switched car off for over 2 hours!
started my 12 mile drive home temp guage straight up to half!! (unusual but surely a dodgy guage) then it went up to 3/4 within about a mile! drove all way til i was about a mile from my garage then it went all the way to the red, red light also on, did NOT smell hot so kept going (as i said just a cheapie)
arrived home and relised my heaters were not working opened the bonnet and this time seemed very hot, radiator fan IS working!! took the dipstick out and let just say you could not touch it! opened water cap i could still see water however i found this strange so i checked the top and bottom hose and these bothe seemed empty! took the bleed screws out and filled with 2 kettles of water (i know this is a no no as i should use antifreeze) took a while to fill!
However when i put the bleed screws back in ive snapped the one closest to the bulkhead!:bang: so i know cant test the car to see if it was airlocked until i get a new screw!
In my personal opinion i think i may have had an airlock and i have now probobly warped the head! however the engine itself is showing no signs of a head problem eg no oil in water or water in oil!
Any advice would be appriciated, i am fully prepared to do the head if its needed but i have seen stranger things turn out to be something minor and you boys are running them all the time so you might have came across this before
sorry for babbling on but i like to give an accurate discription
Many Thanks in advance
