abarth130tc
- Aug 2, 2011
- 50
- 19
Hi have a 2001 1.2 sporting and it has a misfire on number 3 cylinder . Now i have changed the coil and plugs leads but its still the same . Done a compression test and they are all healthy and even . When i take off number 3 plug lead i can see and hear it sparking onto the cylinder head so i know thats fine . Now i have checked to see how many wires go to the coil just to confirm that the ecu does or does not fire each one of the 4 coils separately . 3 wire plug into the coil which leads me to believe the ecu has only 2 live wires going to the coil so i am thinking maybe the ecu is firing the injector late . The head gasket was changed before i bought the car which leads me to believe somebody though it was the head gasket . Also the oil light has come on and wont switch off even after i disconnected the wire going to the switch . Can anybody shed some light on this or have had a similar experience to this
