Technical Do you need to drain the Gearbox when removing speed sensor?
Frazz
Hi, im replacing my speed sensor and im just wondering if you need to drain the gearbox before you remove it?
To be honest - if your replacing the sensor - i'd be draining it anyway
i'm going to assume the Gearbox has never had a fluid change, so drain it
Change the sensor = Wont get too mucky and covering in Fish stinking oil
And then replace with fresh and clean
Might make the car sound a little better too ;)
Ziggy
Ziggy
Im just after changing the clutch, and when doing so i changed the oil so im trying to avoid draining the gearbox so i dont waist my oil.
