im Axle Specialists
Thread Tools
Old 27-06-2011   #1
First Punto!
brendanb581 has donated!
full load tyre pressure
Hi I have lost my manual and need to know the tyre pressures for full load punto . It's an 8v 1.2 x reg elx
brendanb581 is offline Reply With Quote Quote
Old 27-06-2011   #2
Brendan W has donated!
Ireland
Re: full load tyre pressure
165/70/14 2.2/2.1 bar front/rear
Brendan W is offline Reply With Quote Quote
Old 27-06-2011   #3
First Punto!
sorry but shouldnt the rear by 2.2 instead of 2.1? and the front is 2.1??
Old 27-06-2011   #4
Ireland
No the front is 2.2 , rear 2.1. Dont forget the spare , 2.8.
Likes brendanb581 liked this post
Old 27-06-2011   #5
First Punto!
I just dont see how that makes sense, surely you need more in the back seeing as there will be 3 people sitting in it? :P
Old 27-06-2011   #6
First Punto!
and can anyone else confirm?
Old 27-06-2011   #7
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Quote Originally Posted by brendanb581 View Post
People sit between the axles, engine & gearbox sit above front axle so needs to have a bit more in the front tyres. Some cars have the same front & rear but I've never known any Front Wheel Drive car have more pressure in the rears versus the fronts.
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 27-06-2011   #8
First Punto!
so is 2.2 in the front and 2.1 in the rear sound about right for 5 people??
Old 27-06-2011   #9
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
That sounds about right. Over inflation will reduce the contact patch size & could cause the car to lose traction, it also causes heavier wear on the centre of the tyres. Under inflation causes quicker wear on the outside edges.
Old 27-06-2011   #10
Ireland
Scout's honour those numbers are good - fyi they drop back to 2.0/1.9 front/rear for a thing called a 'medium load' in the handbook. Mystic Meg?
Old 27-06-2011   #11
First Punto!
Thanks guys
Old 27-06-2011   #12
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
I run at 32 psi front and 28 to 30psi rears Unloaded
No real problems with Traction at all
When loaded up the car seems to be fine as well
32psi fronts give me better tyre wear tho - and grips alot better
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 27-06-2011   #13
Hi I have lost my manual and need to know the tyre pressures ...
If (like me) you’re not good at recalling tyre pressures – you can reasonably work `backwards.’ Check the max pressure on the tyre sidewall - & knock-off (say) 20%. For example, my tyres read *50 psi max - & I find this a good memory aid to then inflate to 40 psi.
But I say `reasonably’ as it does require some prior knowledge. (I’ve heard of the max less 10% guide - but that’s a little too hard for my taste).
Just out of interest – what is the max pressure given on your sidewall when compared with the given OH figure?
*225/45ZR18
Caravadossi is offline Reply With Quote Quote
Thread Tools
(T) GP Sporting minimum tyre load Dave UK Grande Punto 1 20-03-2010 13:06
(T) Tyre load rating adruss85 Stilo 6 15-02-2009 15:36
(G) Tyre Load index and related issues Irish Steve Scudo 1 30-01-2009 19:29
(T) tyre pressure scorchedbee Grande Punto 7 24-06-2008 13:07
(G) Tyre pressure for spare tyre Cinquelover Cinquecento / Seicento 2 19-02-2006 23:02
