- Apr 8, 2008
- 16,742
- 3,186
Right the car is due for a good oil Change again - tappets are noisey and its black
So start with Flushing
I've been using Stuff From Asda in a Bottle - added it - run engine - Dumped oil
And replaced all the bits
i've also done a Dump - Fill with cheap + Flush - Run engine - Dumped - Replaced all the bits
Question is - it still goes black quiet quickly
So either its a dirty Oil Maker - OR its Got lots of Trapped Dirty oil
so would putting a Flush in - Running Engine - Dumping - Cheap oil + cleaner in - run Engine - Dump - replace all the Bits be a better Job - or a waste of time?
Probably will do the Cheap Oil dump again but is it worth 2x cleaners put through
Also What Flush would people recommend? - Halfords do a Wymns for a £5er i think - is it any good?
And Additives - to go such as this?
Its cheap - and i'm practically at 100k
But a seal Swelling Additive - don't sound a good thing Surly?
Ziggy
Ziggy
