Old 23-05-2011   #1
Petrol drips out, when filled up and smells of petrol inside the car
whenever i fill up at the petrol station, it starts to leak out after about 10 seconds after filling. i never overfill just wait for the pump to stop when it knows it full and take it out.
after paying for it get back in the car and it smells of petrol straight away. i know it has a reserve tank and maybe it's just releasing a bit of pressure. but it shouldnt be happening every single time.
anyone have any ideas what it could be please?
Chris
duggan is mint is offline Reply With Quote Quote
Old 23-05-2011   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Petrol drips out, when filled up and smells of petrol inside the car
the Fuel smell is never a good sign
Make sure the Breather Pipe isn't blocked - as thats what vents the tank
And the reserve is built into the tank - you dont have a seperate Tank for the reserve
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 23-05-2011   #3
Get under the car on the RHS and make sure the breather and filler pipes are 100% ok. BTW fumes are toxic as well as flammable.
DaveMcT is offline Reply With Quote Quote
Old 24-05-2011   #4
SouLz has donated!
Quote Originally Posted by Ziggy122 View Post
Ziggy
Had similar issues.. Use to get some petrol drip by the filler under the car..
Also had petrol smell inside car.
Checked over and the breather pipe has rubbed agaisnt the filler tube causing a small hole.
Apparently its common and known the fiat so check the breather pipe over for holes or simply remove it and submurge in water.
Be careful though it carrys petrol vapours which are the most flammable part of petrol.
SouLz is offline Reply With Quote Quote
Old 25-05-2011   #5
Petrol wont burn but the vapours do.
Old 10-06-2011   #6
i have a similar problem, how much fuel was dripping out of yours because it looks like a lot comes out of mine, i've looked under the car it seems to be the pipe from the filler cap to the tank? is this the same problem or is a new piece of pipe needed?
Joes punto is offline Reply With Quote Quote
Old 10-06-2011   #7
Burkina Faso (Upper Volta)
Wink Re: Petrol drips out, when filled up and smells of petrol inside the car
the answer is not to brim the tank as otherwise its trying to vent itself
it is only a punto after all
s and b is offline Reply With Quote Quote
Old 10-06-2011   #8
i don't brim it is the thing, i fill it a bit at a time when i have some cash, like 10-20 at a time, but still some of it runs straight out of the pipe onto the floor, any suggestions?
Old 11-06-2011   #9
are you putting the nozzle in right?
puntos are a pain to fill and i tend to only just put the nozzle in so as to speed things up and have caused a very expensive puddle before now
Old 11-06-2011   #10
tinytim has donated!
this is likely to be a corroded leaking fuel filter; situated underneath just in front of the driver's side rear wheel; easy to replace (pull off connectors) once you have cleaned the road muck off..
tinytim is offline Reply With Quote Quote
Old 14-06-2011   #11
Singapore
1)check you fuel pump cover(it's under your back bench)- mines not tighten and it leak out once .
2)Fuel tank leak somewhere , most probably the fuel pipe area .
contax mk2b is offline Reply With Quote Quote
Old 14-06-2011   #12
Clean off the filler & vent hoses and check for leaks.
Old 02-04-2012   #13
MFrV1 has donated!
Sorry for the bump, but:
Filled my MK1 up Saturday, but not so the pump cut out. Since done over 40 miles, yet it appears to be leaking fuel from the largest pipe in the o/s/r wheel arch.
It's not a constant leak, but enough to be a worry.
I'm abit baffled as to why there's still fuel there?
MFrV1 is offline Reply With Quote Quote
Old 02-04-2012   #14
Trader Rating: 5
fingers99 has donated!
I'd guess that fuel slops up there while you're cornering?
And @ WhiteSei
Quote Quote:
Petrol will burn just fine as long as it has access to oxygen. But only the vapour will explode (given the correct air/fuel ratio).
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 02-04-2012   #15
I had something like this on a scenic (non fiat) turned out to be the locking ring on the sender unit under the back seat. It had bust and when I filled up - up came the sender unit.
Culminated in overflowing when I filled it completely up, pushed sender unit up so far that by the time I had managed to get to it to push it back (after clearing the forecourt and ruining my shoes) the tank had warped.
Cost me a new tank & new locking ring.
EvoStevo is offline Reply With Quote Quote
(T) horrible petrol smell inside car..... blair Grande Punto 31 09-11-2014 18:49
(G) marea smells of petrol smill Marea 3 30-04-2010 21:07
(T) Unidentified leak smells like petrol garryr999 Punto (Mk2/2b) 5 01-10-2009 22:48
(T) Brava smells of petrol inside? scrobert Bravo / Brava 4 20-07-2009 20:55
(T) odd question, need to get petrol out of car! and petrol octain Q mzhussein Punto (Mk2/2b) 3 02-01-2009 16:18
