Technical punto 16v sporting "y" diagnostic socket fuse
mm0bef
Hi, Is there a fuse for the diagnostic socket supply in the sporting 1.2 16v (march 2001) ? No power to pin 16 of the soket on mine so cant get the diagnostics readout.
Regards
Brian
using the elm327 1.4 . Yes have car running and connection to elm keeps timing out. Read that the elm requires the 12v from the diagnostic socket to work but there is no power from the diagnostic socket.
Regards
Brian
just found it, f39 in fusebox under steering
Brian
