- Oct 24, 2010
- 78
- 35
Hi guys, I have a squeaky rear suspension, which seems to be a common problem (most likely cause by bushes being worn out). I also have a bit of camber on the front right wheel after i crashed into the curb side on as a result of understeering round a corner. I am looking to fix both of these problems and to lower the car at the same time (im not sure how much by yet), and i would also like to replace any parts which are likely to be worn, if it is cheap and relatively easy to do so at the same time. Could someone with a bit of experience tell me what is the best way to go about all this and more specifically what kind-of springs/shockers i should get, how much to lower it by etc.
Any help is appreciated
Halil
Halil
