- Mar 13, 2011
- 7,620
- 1,453
Re: Amber Baby Seat warning light MK2 punto
please dont put crap like this on an internet forum where everyone reads it
you can fire an airbag if you dont disconnect the battery
you have no idea if there is a fault causing power to be somewhere that shouldnt be and a bag given a quick jolt of this would fire it
ive fired enough airbags off to know you treat them with extreme caution
i bet you dont even know the chemicals in the firing capsule do you
go find out via google and be afraid
changing airbag ecu cleared the fault, and i dont believe that stuff about waiting after disconnecting battery to unplug airbag ecu, no power to airbags = no explosion
there is no difference between ecus only by the bottom numbers
left one was the one with the fault
