I have a 55s 1.1 and it failed its mot on the co emissions test and exhaust front pipe. The guy at the garage said that getting a new exhaust front pipe would sort the problem but its made it worse. The sheet says that the lambda is okay what else can it be???? Will getting it tuned help???
FAST IDLE TEST
ENGINE SPEED =2450RPM
CO LEVEL =1.60% (MAX IS 0.30%) FAIL
HC LEVEL =123PPM
LAMBDA =1.00
SECOND FAST IDLE TEST
ENGINE SPEED =2833
CO LEVEL =1.47% FAIL AGAIN
HC LEVEL =65PPM
LAMBDA =1.01
NATURAL IDLE TEST
ENGINE SPEED =818
CO LEVEL =0.29 WHY DOES CO LEVEL PASS THIS TIME?
FAST IDLE TEST
HC LEVEL =123PPM
LAMBDA =1.00
ENGINE SPEED =2833
HC LEVEL =65PPM
LAMBDA =1.01
NATURAL IDLE TEST
ENGINE SPEED =818
