Old 09-03-2011   #1
Camshaft Position sensor
2001 Punto sporting 16v.
I have a problem where by the engine light keeps coming on. When i scanned it it came up with camshaft position sensor. I changed it for a genune fiat item and the light continues to come on!! Is there something else that can cause this to happen???
Lovatt is offline Reply With Quote Quote
Old 09-03-2011   #2
Mk1 Punto Owner - 51 Mpg
MadMan0's Avatar
MadMan0 has donated!
Re: Camshaft Position sensor
Quote Originally Posted by Lovatt View Post
Dirty conection to the sensor could... a bit of wd-40 and a wipe might help?
MadMan0 is offline Reply With Quote Quote
Old 09-03-2011   #3
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
sensor might be fine - sensor might to far away so it cant see the Phonic Wheel - so it flags up the sensor is in trouble
ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 09-03-2011   #4
Hi, thaks, but tried both today to no avail. Could it be valve timing?
Old 09-03-2011   #5
Crankshaft sensor is the Later engine version
i think its called a phase sensor, eitherway
IF a new sensor hasn't sorted it - The Timing may be a tooth out
But i would have thought it'd be well down on power AND it'd be running quiet rough
I'd be checking to see if there is any wiring damage as it heads back to the loom
Ziggy
Meet Bumble-Bee
Old 09-03-2011   #6
MadMan0's Avatar
Does the engine run ok with this error? or does it fail to start as well?
Old 09-03-2011   #7
If the belt has recently been replaced, this is where I'd look first. Cam sensors themselves rarely fail.
D4nny8oy is offline Reply With Quote Quote
Old 11-03-2011   #8
The car does seem to run ok to be honest, when the light comes on the revs momentarily drop but thats all and does start fine
Old 11-03-2011   #9
MadMan0's Avatar
ah, did you reset the error? if not the ecu will still think there is an error even if the part was replaced try clearing the error and see if the light comes back on
(G) PROBLEM!!! my mk2 punto engine doesnt have a camshaft position sensor!! corky Punto (Mk2/2b) 13 03-05-2010 23:00
(T) camshaft position sensor sporting_adz Punto (Mk2/2b) 13 10-11-2009 21:57
(T) where is Camshaft Position Sensor on fiat stilo 1.6? mabd99z Stilo 3 21-01-2009 22:13
(T) Camshaft Position Sensor ? SwissTony Stilo 13 07-07-2007 21:26
