HI Hope some one can help me...
I had my Punto 55 1.1 (1997) to the MOT twice both times failing due to high CO exhaust emission Also I can se Lamda is "pass" Even though is to slightly to high ?
The first test 27/02/05
Fast idle Test: Target:
rpm: 2775 2500-3000rpm PASS
CO: 0.548% <=0.300% FAIL
HC: 31ppm <=200ppm PASS
Lambda: 1.032 0.970-1.030 PASS
Second Fast Idle Test:
rpm: 2604 2500-3000rpm PASS
CO: 0.706% <=0.300% FAIL
HC: 26ppm <=200ppm PASS
Lambda: 1.030 0.970-1.030 PASS
Natural Idle Test:
875rpm 450-1500 PASS
0.492% <=0.500% PASS
I have then changed the Air filter and spark plugs which were quite filthy but as you can see it actually made the CO slightly higher...
I also toke the car for a "high rev" 45 min drive to the MOT center but no difference... :bang:
Second Test 09/03/05
rpm: 2650 2500-3000rpm PASS
CO: 0.772% <=0.300% FAIL
HC: 41ppm <=200ppm PASS
Lambda: 1.037 0.970-1.030 PASS
rpm: 2807 2500-3000rpm PASS
CO: 0.704% <=0.300% FAIL
HC: 28ppm <=200ppm PASS
Natural Idle Test:
846rpm 450-1500 PASS
0.539% <=0.500% FAIL
Kwick-fit then adviced me to change the back box for £122 because it was ratteling (apparently) and it would help to keep the pressure-? and lower the CO - but guess what...No change what so ever! :bang:
Now a Local garage have quoted me £70 for a two hour engine test..? plus approx £88 for two hours labour correcting the problem? of course VAT and parts are on top of that.
They were saying that it could be the temperature sensor?..maybe the lamda and last resort the ECU...make sence???
I am very novice when it comes engine magement systems...but what about the fuel incector ? if the spary pattern is all over the place this must clearly result in a poor fuel economy? - is this easy to check?
lots of questions..lots of answers - Hope you can help
Natural Idle Test:
Natural Idle Test:
