can anyone tell me where the washer jet pipe feeds through the car for the rear jet? i have de wipered my rear, no longer need the jet and have an issue with the washer motor valve so the rear jet leaks when i use the fronts. i have used silicone to block the jet holes so this dosnt happen, but have had an issue with the spare tyre well flooding. i think it may be a leak from the jet feed pipe as i cant see any evidence of a leaky seal, but not sure as i dont know where the pipe goes to reach the jet. i was thinking of just removing the pipe and blocking it off from the motor valve to stop this (if it is the issue).
