FIAT Auto Specialist Team
Old 08-02-2011   #1
Punto Mk2
JTG0710 has donated!
Clutch!!!!
For a while now my car has been making a funny noise when in gear most notciable in reverse when moving slowly, over the weekend the car would judder heavily in 1st and reverse when setting of ,then this morning the clutch started slipping in 4th, it now slips in 3rd 4th and 5th when booting it. 1st and second seem ok,
has the clutch gone/going, only had it replaced about a year ago ,
could the noise be a release bearing, its a whining type noise but low in pitch
any help much appriciated
JTG
JTG0710 is offline Reply With Quote Quote
Old 08-02-2011   #2
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Re: Clutch!!!!
i'd Say clutch as once it starts to slip its going
HOWEVER!
There could be the bad news of the Gearbox Oil seal is leaking and its now all over the clutch
Eitherway the Car has to go on ramp to have a look
If Seal is leaking its a new Clutch as well as either a new box or a new seal
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 08-02-2011   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Clutch!!!!
Ziggy pretty much sums it up while playing guitar.
Don't be slipping the clutch as that will put a heat cycle in the flywheel and you'll need a new one of those too.
D
Old 08-02-2011   #4
Re: Clutch!!!!
Generally on a Punto a the clutch will drag before it slips so a slipping clutch often means an oil leak.
Dont let it rev while the clutch slips as the flywheel will get overheated and might even warp or crack and at the least can get scored.
Quite probably its the gearbox input shaft bearing and oil seal which will need a gearbox repair to fix it. Its probably better to get a service reconditioned box as other stuff will be packing up.
DaveMcT is offline Reply With Quote Quote
Old 08-02-2011   #5
Re: Clutch!!!!
Quote Originally Posted by WhiteSei View Post
its Hit and miss with 2nd hand boxes
I'll admit - i'm on my 4th Box
1st Box (original to me) - Diff Exploded spectacularly
2nd Box - Input Bearing had Failed (didnt know about this fault till box was in and had been for a month) As a result the Gears were not meshed properly (too loose) and decided to eat each other till one day - there was no more power input
3rd Box - 3rd Syncro and Yet again Diff Exploded / Died (lots clunking)
4th Box - lasted longest, but getting noisey!!! but still feels fine
So its one of those things
Atleast with a Recon Box - there is a warrenty, and they are serviced and checked over
Probably my next step if i need a new Box
I found my clutch was just slipping, didnt get any drag with it, just one day the revs started popping up
Ziggy
Meet Bumble-Bee
Old 08-02-2011   #6
Re: Clutch!!!!
The diff is right down the bottom of the box could be it eats bits from other broken parts and then explodes next time you take a tight bend.
Better with a properly rebuilt gearbox and warranty and probably cheaper in the long run.
Old 08-02-2011   #7
Re: Clutch!!!!
Defo - just an example of how much it cost me
2nd box 50 + 160 fitting = 210
3rd Box 200 + 160 Fitting = 360
4th Box replaced under 3month warrenty + 100 fitting = 100
Total = 210 + 360 + 100 = 670
Where as a Recon is 300ish
Ziggy
Meet Bumble-Bee
Old 08-02-2011   #8
Re: Clutch!!!!
I had the diff explode on an old MG Metro taking a left turn in a side street. The car stopped with a trail of oil and the bang was so loud people came out of their houses to see who was shooting.
Old 09-02-2011   #9
Re: Clutch!!!!
Luckily i was just pulling back home - i have to turn left to park where i park - the car pulled Really badly to the right - Loud Bang - Car Stalled - Smell of fish as G.box oil pea'd out
Ziggy
Meet Bumble-Bee
Old 09-02-2011   #10
Punto Mk2
Re: Clutch!!!!
last night on the way to work it was fine, no slipping when booted, however when on the way back it was slipping loads
Ideas?
Old 09-02-2011   #11
Re: Clutch!!!!
Quote Originally Posted by JTG0710 View Post
Ideas?
Oil has been rubbed off - but as you got the gearbox hot again its leaked
So while you were at work it dribbled till it was cool - you drove home with an Oil Soaked Clutch again
Get it to the garage
As Oil + Heat + Friction is asking for a really bad smell / smoke
If it seriously hot and might catch fire
Plus the heat will be warping your flywheel
Ziggy
Meet Bumble-Bee
Old 09-02-2011   #12
Re: Clutch!!!!
It needs a gearbox rebuild and a new clutch. Continue driving and the gearbox wont be accepted for rebuild (too much damage) and the flywheel will burn out. Doing nothing can be very expensive.
Old 10-02-2011   #13
Punto Mk2
Re: Clutch!!!!
on motoway today it jumped out of 5th and went into neutral, it went back easily enough and hasnt done it since, is this clutch related,
also had the car in the air last night very loud ratterling noise like something is loose around the clutch area(release bearing ?)
any ideas ?
JTG
Old 10-02-2011   #14
Re: Clutch!!!!
any ideas ?
JTG
If its ratteling - the damage is done
it jumping out of gear IS NOT a good sign
Going back in easily is not a good sign either - unless you got the syncro speeds right it popped in - its hard and unlikely - i'd be very careful!
Gearbox could be dry and now metal bits are floating around
The Clutch could have overheated due to the oil burning off - Damaging the release bearings the Shaft - warped the Flywheel
Strip down - replace parts and see if you cure it!!
But all these sound like a combination of the clutch and gearbox - which we did warn you about
Ziggy
Meet Bumble-Bee
Old 10-02-2011   #15
Re: Clutch!!!!
The box has failed and its chucking oil on the clutch.
Keep on going and you'll need a NEW gearbox as it will be beyond rebuilding.
(G) Clutch & gearbox change - Mr.Clutch - Mk1 Punto 60S FiatMAW Punto (Mk1) 13 08-01-2011 21:03
(T) wil changing my clutch cable make it eaiser to push my clutch down luke64 Cinquecento / Seicento 10 03-06-2010 13:53
(T) clutch went ripped gear box up or did it? or did they replace clutch like i paid for? charlene homer Punto (Mk1) 8 28-02-2009 10:08
(T) Gringing And Scraping Noise When Clutch Released Only Stops When You Depress Clutch allsortspete Punto (Mk2/2b) 4 05-07-2007 21:45
(T) Changing hydraulic clutch gearbox to take a cable clutch? 4paws Uno 10 23-03-2006 14:56
