im Axle Specialists
Old 26-01-2011   #1
Fiat Punto turns over but wont start!!
I have a fiat punto 1.2 8v 2001 which i have just changed the engine, i have removed the ecu and all of bits and placed them on the replacement engine. I have fitted the engine but it doesnt want to start.
I seem to have no spark when placing a spark plug against the cylinder block and turning it over. I do know that im getting fuel delivered to the engine but this bloody thing wont start!!!
Could connecting the HT leads in the wrong order cause it not to spark, if so could someone please tell me the order to connect the leads as im about to take a hammer to this car and I wont be Fixing It Again Tommorow!!!!
BMJay is offline Reply With Quote Quote
Old 26-01-2011   #2
Trader Rating: 5
fingers99 has donated!
Re: Fiat Punto turns over but wont start!!
All of the bits? Like the immobiliser transducer ring?
Check for fuel past the injectors. If fuel up to the injectors but not past them (and no spark) it'll be the TDC (or crank) sensor.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 26-01-2011   #3
Quote Originally Posted by fingers99 View Post
If i have used the ecu from the old engine will i still have to change the transducer ring, if so where is this located?
Thank you for your help.
Old 28-01-2011   #4
Trader Rating: 5
Quote Originally Posted by BMJay View Post
No. Did you check for fuel past the injectors and spark?
M12 fund 20
Old 31-01-2011   #5
Sorry to be so ignorant but what do u mean? Do you mean disconnecting the fuel rail to see if it squirts? I am getting one code that keeps returning p1325 knock sensor, but im sure that would stop it from starting.
Thanks for your help.
Old 31-01-2011   #6
I've set the timing and it still dont start the pulley is definatly on correct, all timing marks are lined up. Some mentioned to me about setting the timing mark through the bell housing but all i can see is the pressure plate and no notch to line it up with.
Old 31-01-2011   #7
Trader Rating: 5
Fuel past the injectors = wet plugs. The order of the leads is embossed on the coil pack carrier. The knock sensor is located in the middle of the block at the rear of the engine. Make sure it's connected up.
Check those.
M12 fund 20
Old 03-02-2011   #8
Check those.
There is fuel past the plugs, but would a knock sensor stop a car from starting?
Old 04-02-2011   #9
Somebody please help me why haven't i got no spark???? I've set the timing and still cant get a spark please help or do i need to bring this engine back where i got it from??
Old 07-02-2011   #10
Can someone tell me if im right or wrong? i've run out of ideas but i think it could be the key. Does a mk2 punto come with a red (master) key???
Old 07-02-2011   #11
OP is using the original ECU so the system wont care about the a new engine.
Knock sensor may be fail safe so make sure its connected.
Cam or crank sensor might be faulty.
Press down the shraeder valve pin on the fuel injection rail. No pressure and/or no fuel coming out shows no fuel getting through.
Check the immobiliser antenna is connected under the steering column cover
DaveMcT is offline Reply With Quote Quote
Old 07-02-2011   #12
Quote Originally Posted by WhiteSei View Post
Thanks mate i'll give that a try when i get back from work.
Old 07-02-2011   #13
Davie Thistle has donated!
.........this happen'd on my mates mk1,
we ended up changing the coils,
mibbees try that?
get a set in the scrappy for about 20 quid.
Davie Thistle is offline Reply With Quote Quote
Old 08-02-2011   #14
Quote Originally Posted by Davie Thistle View Post
mibbees try that?
Ive got two sets of everything from the previous engine and the new engine so ive tried changing over all bits and still getting no luck!!
Old 08-02-2011   #15
What about the crank sensor? The ECU needs to see the engine is actually turning before it fires plugs and fuel..
bravo wont start but turns over stevevac44 Lets Talk FIAT 2 06-01-2011 22:02
(T) fiat punto wont start most days sharon28 Punto (Mk2/2b) 3 14-10-2010 22:06
(T) fiat punto wont start qq erfquake Punto (Mk2/2b) 16 13-01-2010 20:03
(T) 1.9 JTD turns but wont start gs1100hardtail Punto (Mk2/2b) 5 26-06-2009 20:50
(T) 1999 FIAT PUNTO 75 SX wont start marrzie Punto (Mk1) 4 10-02-2009 09:11
