OK, i bought a MK1 punto last november (55 SX). I had both swing arms replaced on the back. After this was done i was asked if i had a red key for the car, which i don't. So i was told i need to get back onto the guy that sold me the car.....
I had a quick look through the previous posts on this and I have found a lot of posts on the subject, just to clear it up for me.
I know that the red key is used for the ECU, but i am not sure what an ECU is. Can anyone explain.
When would I need the red key? And where can i get a replacement?
Also i have a new radio for my car,
If i disconnect the radio from the battery, i will then have to input a code to get it to work again. But if i do not want the radio it doesn't matter.
I know it sounds stupid but i won't need to use the red key if i replace the radio.
Finally....
What common problems may i encounter with my car now it has done ~86000 miles.
I have had my rear swing arms done, and welded my seat so it no longer leans to the left.
thanks in advance
Jon.
Finally....
thanks in advance
Jon.
