SeanoPunto
- Jan 3, 2011
- 6
- 5
I have a 51 reg Punto ElX it is my first car and I've managed to have it now for 3 years with some problems along the way that have mainly been repaired by my brother in law.
I am now getting to a point where I don't see the point in owning a car if I'm not going to bother learning something about it so have been trying to do little jobs on my own via the haynes manual.
What I need to know is how to bleed/drain the coolant system so that I can put some water & anti-freeze/coolant mix in before we get our next big freeze!
Now I've seen this done before by my brother in law and am pretty sure all I need do is dis-connect the pipe from the bottom of the coolant storage unit and simply let any liquid drain away while the engine is off & cool and then re-connect it and add the appropriate mixture/level of anti-freeze & coolant dependant on how cold I'm expecting it to get!
Now what I'm asking of the members here at Fiat forum is, have I understood this process correctly and is this basically the correct method of bleeding/draining the coolant system on a 51Reg fiat punto El-X?
Feedback would be much appreciated=]
