Hi all,
My punto is over fueling like mad, to the extent it would not start. Apparently the reason it is overfueling is that the injectors are reading to be remaining open for a period of 3 to 5mm seconds and the norm should be about 1mm. The ECU seems to be reading all the sensors OK and the coolant temp sensor appears to be OK. Any ideas on what is causing the inectors to remain open for so long? Any ideas / advice a appreciated.
