andy171baz
Hi all, had front tyres fitted recently,noprobs, couple weeks later POWER STEERING fail while out driving,so pluged in my diag tool to pull the codes, i have read the link about column changes and if position sensor is shown then a column is needed full stop is the statement.
So i will keep this thread purely for my repair on this subject, report what i do and what happens etc.
2004 1.2 16v punto, pics:
1- ecu data 2-codes stored 3-calibration programmes carried out.
4-I have operating data graphs of the steering system showing working values,amps,volts,steering force through steering wheel,but will keep these to 1 side so as not to confuse to much.
Cleared the codes, carried out the calibrations and road tested: all well no faults or symptons yet, i take onboard the comments about battery and other ecu systems on the car such as abs, all system clear no faults, i will be carrying out a battery load drop test over the new year break to test the battery. Will report back after battery test and monitor the situation.
Any one wanting code reads (eng/abs/airbags/eps/dash/serv lights etc) drop us a pm, may be able to help.
Baz
Baz
