Old 29-12-2010   #1
Bush has gone again!! Third Time
Hi all,
I had a problem with knocking/clanging when my car moves over bumps, dips and such like.
And I had it fixed. Was told it was the bush on the passenger side wheel. I watched the guy fix it.
And the car was working like normal again. Until it started happening again. So I took it back to the guy he fixed it. It was probably a year between those two fixes.
But today I drove over a series of speed bumps (NOT very fast, taking some care) on a road and half way through the road I kept hearing the same noise.
I checked shock absorbers, they are fine.
How can I get the bush fixed once and for all?
The sound is not good.
Is there a way to fix?
If I complain about the speed bumps to my council will they do anything?
I dont usually encounter many speed bumps on my journey and was un forseen. But they are kinda high compared to others I have seen.
cataleptic_state
Punto Active Sport Mk2b 8V 3dr Manual 05
Formula1Reporter, Pricebargin.co.uk, CompareYourKnickers.co.uk, Horse-Master.co.uk,topendmotors.co.uk
catalepticstate is offline Reply With Quote Quote
Old 29-12-2010   #2
Re: Bush has gone again!! Third Time
Get the car checked for alignment on a body-shop chassis jig. Three new bushes in such a short time suggests the chassis might be bent and putting abnormal stress on the suspension joints.
DaveMcT is offline Reply With Quote Quote
Old 29-12-2010   #3
How much would a new bush cost?
The first time I went somewhere, I went to Kwikfit and they gave me a stupid price of 150 just for the arm.
Theres nothing wrong with the arm.
I had a stupid girl knock into my car, my wheel was out and got knocked, but it was not the passenger side that got hit.
cataleptic_state
Old 29-12-2010   #4
The suspension bush repairs could have been bodged but three times over is unlikely.
The car should be jig checked anyway.
Old 29-12-2010   #5
The first two times the bush was put back into place and tightend.
What would the normal process be? Replace the whole fixture?
cataleptic_state
Old 29-12-2010   #6
Would be handy to know exactly which bush you were talking about?
Wishbone front mounting?
Wishbone rear mounting?
ARB outer mounting?
Was it a genuine Fiat bush, or cheap pattern part? Some pattern rubber mounts are utter cack (I've known some to last barely a few months).
D4nny8oy is offline Reply With Quote Quote
Old 29-12-2010   #7
Its the front left. Not drivers side.
cataleptic_state
Old 29-12-2010   #8
The three bushes I mentioned are all attached to the wishbone, which one of the three are you moaning about?
Old 30-12-2010   #9
cataleptic_state
Old 30-12-2010   #10
So this one?
Name:	Punto wishbone.jpg
http://cgi.ebay.co.uk/FIAT-PUNTO-99-06-FRONT-WISHBONE-FRONT-BUSH-OE-QUALIT-/120609851390?pt=UK_CarsParts_Vehicles_CarParts_SM& hash=item1c14e847fe
If they're anything like the pattern Ford Mondeo ones my colleague replaced (3 times in as many months before he gave up and replaced with a genuine complete arm), then I wouldn't bother. Fit a new (decent make/OEM) wishbone.
Old 30-12-2010   #11
If replacement bushes are available they should be pressed out and in; otherwise fit a new suspension arm.
For better handling (but more road noise) fit poly bushes.
Old 30-12-2010   #12
Yes D4nny8oy, thats the one.
I've had a look at the Poly Bushes, the idea of increased road noise does not appeal to me, but why would they give you better handling?
All I can see is that they are both made of similar materials.
My handling is already quite good, what kind of improvement will I see from that
cataleptic_state
Old 06-01-2011   #13
I found this: http://www.eurocarparts.com/ecp/c/Fi...51e724763&ABAB
I am going to get this tomorrow.
But in the description/title it says Punto 188.
Would this bush still work for my mk2b?
These guys are up the road from me and its quicker than sending off for a delivery.
cataleptic_state
Old 06-01-2011   #14
Noob for life
SamuraiDragon's Avatar
SamuraiDragon has donated!
Quote Originally Posted by catalepticstate View Post
it should do. mk2bs are the same car with a different nose. mechanically they are the same as far as i know.
SamuraiDragon is offline Reply With Quote Quote
Old 06-01-2011   #15
The mk2 and 2b are both Model code 188.
However, the bush I placed an arrow next to in the picture above is not the Anti Roll bar bush. So which is it that's faulty?
worth 2 in the bush? dave Leisure Lounge 17 17-09-2006 01:04
Boneless Bush Dobby Leisure Lounge 1 10-09-2006 02:16
Driving a modified car sucks from time to time - A night to remember Randomman Leisure Lounge 44 14-03-2006 18:16
Bush wins the election... Steven Leisure Lounge 25 04-11-2004 12:25
Bush V. Kerry jasper Leisure Lounge 5 02-11-2004 20:56
