Old 17-12-2010   #1
Lightbulb Indicator still comes on when i brake!
Hi am pretty new so am not very good with technical language.
I had a brake light go out and i managed to fix it myself however when the bulb was broke the rear left side indicator came on constant like a brake light would. I thought this was some sort of safty feature and would fix itself once the new bulb was installed but its still coming on when i brake.
Can anyone help?
thanks.
JackyBoy1993 is offline Reply With Quote Quote
Old 17-12-2010   #2
will4318 has donated!
Re: Indicator still comes on when i brake!
Check all the connections on the break lights are good, the warning light should go off when there is a new bulb.
I would start with the one you had to replace, check the connections are clean and dry etc
will4318 is offline Reply With Quote Quote
Old 17-12-2010   #3
One of the conectors has a white poweredy crust on it. Is this normal?
Old 17-12-2010   #4
nope its not, that is probably your problem, try gently sanding i off or using a wire brush or something. be careful not to sand the contacts down to much though
Thanks JackyBoy1993 thanked for this post
Old 17-12-2010   #5
Noob for life
SamuraiDragon's Avatar
SamuraiDragon has donated!
seen this problem b4. was driving behind a punto the other week with the same problem... may have even been u. lol. best bet is to clean up all the contacts and with any luck, the problem should go away. may be worth looking deeper into why the connections got like that so it dont happen again.
SamuraiDragon is offline Reply With Quote Quote
Old 17-12-2010   #6
Quote Originally Posted by SamuraiDragon View Post
the must have been some water trapped in there at some point. maybe a bulb was changed in the rain and some got it or something. just give it a good clean and as long as its all dry just keep an eye on it
Old 17-12-2010   #7
Noob for life
also, check all the seals around the lights and boot.
not sure how good it would be for this, but a lil squirt of wd-40 or silicone spray may help keep to keep the contacts clean and water free.
Old 17-12-2010   #8
Im not sure, it might cause more connection problems its self
Old 17-12-2010   #9
thats exellent it worked. many thanks.
(G) Rear Lights, brake and indicator PaddysMum Stilo 5 19-06-2009 14:08
(T) When i brake my right indicator cums on help xGooN TooNx RAF Punto (Mk2/2b) 3 25-02-2009 23:32
(G) Brake Pad Wear Indicator on GPS phostead Grande Punto 3 02-07-2008 01:24
(G) Punto with hand brake indicator issues... schmem Punto (Mk2/2b) 9 03-04-2006 13:36
(T) brake diag indicator on when turning right kezzy Doblo 2 18-10-2005 15:32
