Thread Tools
Old 14-12-2010   #1
got new clutch installed, 2 days later no gears
Hello,
I recently bought a new clutch and had it installed. I drove it for around 2 days and then i heard a loud crunching and bang noise then there was no gears. Reverse worked enough so i could park it but then it made a bang and then didn't work at all. I'm wondering if the guy who installed the new clutch didn't bleed it. If this is so, how would i do it and what would i need?
lewisusher is offline Reply With Quote Quote
Old 14-12-2010   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: got new clutch installed, 2 days later no gears
Have a look at the reservoir.
Where is the fluid level?
D
Old 14-12-2010   #3
Likely the slave cylinder didnt like being disturbed and the seals have just failed.
DaveMcT is offline Reply With Quote Quote
Old 15-12-2010   #4
Quote Originally Posted by lewisusher View Post
Hello,
If the slave cylinder is faulty, usually reverse is the hardest to get, plus you'd only get grinding while trying to select gears- not while cruising along.
Does the clutch pedal feel normal?
Can you select gears with the engine off?
D4nny8oy is offline Reply With Quote Quote
Thread Tools
(G) clutch and gears mrcarrots Punto (Mk2/2b) 6 11-05-2009 12:35
(G) clutch/gears zakari99 Bravo / Brava 2 25-04-2008 11:13
(G) clutch/gears sharonbowen Cinquecento / Seicento 5 13-06-2006 21:45
(T) Clutch or gears Warful Cinquecento / Seicento 5 18-01-2005 16:39
(T) another 1242 Q - clutch, gears etc. blitzen Cinquecento / Seicento 11 26-09-2003 22:40
