Thread Tools
Old 12-12-2010   #1
Malta
Is it possible to change mk2 16v coil to mk1 16v coil?
As the title says, i would like to know if it is possible to change the mk2 16v coil to the 2 mk1 coils as i have a friends car with a suspect coil failure and i am being asked for 220euro for one here in Malta whilst i have 2 mk1 coils lying around which i am sure are not faulty!
Thanks for your replies in advance.
ryn079 is offline Reply With Quote Quote
Old 13-12-2010   #2
Re: Is it possible to change mk2 16v coil to mk1 16v coil?
not sure, but in the UK a mk2 coil pack is 30, find someone you know and trust off the forum and send em the cash via paypal so its insured and get em to send you one it'll be a lot cheaper.
I tell it like it is so if I offend you.....Unlucky.
Rule No.1: If it don't fit, make it fit.
Rule No.2: If in doubt, kick or hammer it.
Sqwidge is offline Reply With Quote Quote
Old 13-12-2010   #3
DaveMcT is offline Reply With Quote Quote
Old 13-12-2010   #4
Malta
Hi guys, my problem is that plug no.3 is wet. changed the plugs and no.3 is wet without deposits and clean as if it has just been taken out of the box. I also tried two other ht leads but nothing changed.
will check resistance of coil, but could this be something mechanically wrong? car is punto mk2 1,2 16v.
Old 13-12-2010   #5
The plugs are fired in pairs so one spark is wasted on the exhaust stroke. They pair at 1 & 4 and 2 & 3.
Sometimes and unusually new spark plugs can be faulty so put the suspect plug on the opposite cylinder pair. Then, to test the coil (using used plugs you know are good) swap the leads over on the pair with the fault. If the other cylinder goes dead its the coil. If it stays the same you have a cylinder problem.
Old 17-12-2010   #6
Malta
Hi Whitesei, first of all i would like to apologise for not replying back and thanks for the hint. It looks like the coil is knackered as i put a plug in ht no.3 and ran the car and no sparks where noticed, even though coil was checked with an ohm meter and values are ok. Have to find a cheap enough coil to get to Malta.
Thanks for your help.
Thread Tools
(T) Multipla 1.6 16v Injector or Coil Problem? dadams Multipla 7 17-08-2013 13:22
(T) 16v coil needed swifty100 Tipo (Classic) 4 16-09-2010 12:21
(T) 1.4 16V coil pack and HT leads mattyd Bravo / Brava 3 18-06-2007 21:06
(G) 16v coil pack resistance help weewillywinky Punto (Mk2/2b) 2 22-05-2007 13:56
