Technical Wipers not stopping
baldsimon
My Punto has developed an intermittant problem with the Windscreen Wipers. On occasion, they do not stop working. That is, once turned on (even on intermittant wipe) they run continuously. When the wipers are switched off, they may continue to work for several minutes until they finally decide to stop. On one occasion I had to pull the fuse so that I could get home (after the rain had stopped).
Does anyone have any suggestions about where to look to fix this? I suspect that the Live_to_Park function on the wiper motor may be at fault.
Thanks in advance,
S.
That will be the relay up the swannie, sounds like the contacts are not breaking when they should. A replacement is the only solution, quite cheap though (a couple of quid) ;)
I guess that checking the relay quick and easy to do, but how do I know which is the correct relay?
I think that it's one of the relays in the panel by the driver's footwell - do I need to pull each relay in turn to discover the right one? If I do this am I likely to cause other problems?
S.
thrs a diagram on the panel near the switches i cnt remba which 1 it is but thr shud be a pic of the wiper 1 and simply find it on the board.
i had a similar problem before, i wire had frayed from the ECU so i had it short cicuited and the problem stopped it was with the back wiper it continuously worked on its own and had to have the fuse taken out evn when the car was off. :rolleyes:
famz
i think the right red relay does the wipers....i have an annoying clicking noise either from relay or wiper stork/motor which still cant solve. but from trying fix my annoyin noise i think the right red one is the one! :)
thats to stop the wipers juddering across the screen (which i had to do once) but this is different its a clicking noise which shakes the wiper arms but it only doing it when the lights are on
Stops juddering & clicking from switch/fuse box area.However didn't realise it was only with lights on i'll look into it(what year punto is it?) but sounds like body computer/power problem? Does it do it with say heated rear window on insteard of lights?
i have same problem its to do with the fuse in the wiper stalk itself apparently, its buggered, and if th wipers stop working completely (once happend 2 me) thn ul have to get another stalk. its not the motor.
its v reg 99. mark 2 1.2 16v sporting. yeah if could look into that be awesome as its be driving me crazy iv run out of ideas! when lights are on it does it...then if full beam or fogs are on it gets faster. also the heater speed effects it. when lights are off it doesnt do it and when wipers are running it doesnt do it HELP! :(
i think you should get the stalk itself checked, th heater and lights affect the clicking, the stalk is one big part which has the lights connected too so if u get the part ul hav to connect the light connector too.
also i suggest u get a pro to do it cos the whole steering wheel has to come off n have to be careful u dnt set off the air bag and all its well long n takes round an hour or 2 to do. :rolleyes:
mmmm doesnt sound good! so if i was to ignore it wil it just get worse and eventually wipers will stop working completely? so whats caused this to happen? any ideas how much these stalks cost?
brand new cost bout £110 second hand u can get for bout £30+, it jus gonna keep clickin it wnt stop thn when the fuse blows th wipers will stop completely n ul hav 2 get new stalk no matter what. its not really tht bigger job its jus a hassle n the clickings wel annoyin i jus try not 2 use wipers where possible n keep heater on 2 cos it dnt make no noise thr n play loud music 2 get rid of clickin noise lol (y)
famz
www.247spares.com
fil in the details and sumone should contact you back within 45mins and if thy dont tht means thy not got one. thy deliver next day. (y)
if not thers the scrap yard.
Hi!
The SILENT WIPE system has been designed to replace the whole wiper system on the Fiat Punto Mk 2, because of the many reoccuring problems. (n) A few customers have had Mk2 linkages actually breaking which is why we now manufacture a replacment system as Fiat charge £105.00 :( just for a new linkage! We have upgraded the system for more rigidity and used upgraded materials to try and alliviate all of these problems. Then we have added the two high quality wiper blades, as the better the blade rubber the better the wipe! (y)
We have added this to your forum just so that if anyone does have these problems we can help! As you will see Dave (Sticky) has tried the linkage for us and recomends it. As you are all Forum members we are also offering it to you at a discounted rate. We have them available on ebay at the moment for £89.49 + p+p, but for Forum members we can offer it to you for a discounted rate £78.00 all in.
If you are interested either contact me via email [email protected], check our website www.wipex.co.uk or call us during office hours at Wipex on
T: (+44) 01684 310028
We look forward to hearing form you! :)
