D dames483 New member Joined Nov 25, 2010 Messages 1 Points 1 Nov 25, 2010 #1 .... i get a grinding metalic noise when turning right, but only when its nearly locked all the way. any ideas? punto 1.2 8v V plate also while im here , which is the right break fluid for this motor. many thanks Damian
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Nov 25, 2010 #2 DOT 4 fluid. Difficult to say on the grinding front. Is the ARB centred? See if you can work out what's rubbing.
D4nny8oy Established member Joined Apr 6, 2007 Messages 2,883 Points 433 Location Yep, still here. Nov 25, 2010 #3 You've probably bent the disc backplate in towards the disc when fitting the wishbone (usually at the bottom). Just get a screwdriver in there and lever it slightly away.
