FIAT Auto Specialist Team
Old 13-11-2010   #1
Play in front wheel and disc?
Hi, new to the forum as I've just got my punto last weekend
While I had the car jacked up there was a lot of play in the N/S front wheel and disc, I'm pretty sure this is a wheel bearing but can anyone confirm this?
Another problem I have is I somtimes get the fuel injection light up on the dash when this happens theres not change to the way the car drives and no lose of power not sure why the light goes on and off?
punto225 is offline Reply With Quote Quote
Old 13-11-2010   #2
Trader Rating: 5
fingers99 has donated!
Re: Play in front wheel and disc?
Wheel bearing if play at 6-12 and 3-9. You can generally feel harshness, too. Other (scary!) possibility is a loose hub nut. If Mk2 punto, get the codes read -- it's OBD2 compliant, so should be doable anywhere.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 13-11-2010   #3
Yeah hub bolt is tight... would it be safe to drive it to work this week until I can get it sorted?
Old 13-11-2010   #4
Trader Rating: 5
Well, safe(ish). I'd not do it knowingly. but people (even PCC editors!) seem to get away with it.
M12 fund 20
(T) steering wheel play andy majorca Cinquecento / Seicento 1 09-12-2008 15:35
(G) Front wheel side play [lower wishbone?] mhowse Stilo 4 15-11-2008 13:54
(T) play on the wheel colin07 Stilo 9 17-06-2008 20:23
(T) Slight play up and down with steering wheel? robbocop Punto (Mk2/2b) 1 06-02-2008 16:59
(G) Steering wheel play... klr142 X1/9 6 18-12-2004 17:11
