Technical yellow flashing light on dash
david295
Established member
New Brighton Wirral
I have today got the clock system out of a mk2 sport from scrap yard, mine did not have a rev counter, so i did not expect the rev counter to work when i put the clock system in from a sport, but surprise it did, every thing works perfect, i now have a temp gauge.
there is a yellow flashing light on dash it constantly flashes, it did not do this on my other clock system, it use to go off after about 3 seconds. it is not the engine management light
you will need a proxy alignment so the clocks and warning lights all talk to your body computer and ecu properly
Does it vary with car to car?
AS mine went from standard clocks (no rev/temp) to the Sporting Clocks, Only My Display with clock on flashed with mileage
Also See if you've got any Auto-Electrician near by, as they should be able to correctly Align and Set Mileage
(btw if your mileage is higher on new clocks compare to your car, your car will have gained some miles. need a clock set which is lower then yours cars current mileage)
Ziggy
