Thread Tools
Old 17-10-2010   #1
Benny 1992 has donated!
power steering light on but...
ive got a bit of a wierd problem lol, my power steering light has come on but the steering still feels as good as ever and ideas
Project X1/9 coming soon.....
Benny 1992 is offline Reply With Quote Quote
Old 18-10-2010   #2
Re: power steering light on but...
Hi, charge battery,take it for a good run if its been standing or replace if its old, electrically operated power steering so draws a fair amount of current,power steering light will come on because it senses a drop in power & when temperatures outside drop more demands are put on the battery which needs to be in top condition.
inki is offline Reply With Quote Quote
Old 18-10-2010   #3
Battery is only needed when the engine is ticking over - at low revs the generator wont be making enough power to drive everything.
In cold weather just after starting the engine perhaps with heated window and light etc, a weak battery can struggle enough to affect the power steering.
Get it tested with a proper battery stress tester. Replace if its weak and get the best spec you can. The extra few s are good insurance.
If the power steering is failing a reconditioned exchange power steering column is about 180 plug and play with 2 years warranty.
DaveMcT is offline Reply With Quote Quote
Old 18-10-2010   #4
Ziggy122 has donated!
Eggs Champion, Fruit Pairs Champion
Make Sure that your battery is giving enough juice
Cold Morning kill Car batteries - and if the Voltage/Amps aren't enough the PowerSteering wont startup when the car starts up
Also check all the wires going into the ECU Give them a little clean and hopefully it should behave
I found also Moisture Makes the whole ECU/Motor System display faults
I'd definatly Try heating the ecu and Motor up carefully with a hairdrier on, i left some silica packets around that area too - be surprised how the cold air from outside gets down there.....
Ziggy
!!WANTED!! 3dr Mk2 Punto Roof Bars !!WANTED!!
Meet Bumble-Bee
Ziggy122 is offline Reply With Quote Quote
Old 18-10-2010   #5
My car is parked outside but no damp inside. Check there are no rust holes in the floor and the poly films behind both door cards are unbroken.
Old 18-10-2010   #6
cheers lads, but i dnt think its the battery cos it had a full charge when i come bad off holiday and it a massive battery 1 id find on a transit van lol
Old 18-10-2010   #7
Trader Rating: 1
Mine did exactly the same but i found that after taking my car for a couple of long runs the light stopped coming on and is now working fine again.
This is quite a common problem with Puntos of this age and i woudnt wory unless you start lossing you power stearing while driving.
Ashjj is offline Reply With Quote Quote
Old 18-10-2010   #8
Quote Originally Posted by Ashjj View Post
thats wot i was thinking mate
Old 18-10-2010   #9
I like to be different!
bredsticz's Avatar
Trader Rating: 1
bredsticz has donated!
Mine did it. replaced the batttery and all good since
Any MK2 punto parts needed? Let me know!
I have 2 punto's worth of parts for sale
bredsticz is offline Reply With Quote Quote
Old 18-10-2010   #10
If the battery is on its way out - Recharging it with a mains charger thing Wont make it better
The Battery still wont give out enough juice even when you charge it up
New Good Quality Battery Is a MUST
Ziggy
Meet Bumble-Bee
Old 18-10-2010   #11
done around 100 miles 2day and light has not been on how wierd lol
Old 18-10-2010   #12
Quote Originally Posted by Benny 1992 View Post
Could be a dodgey Connection
A good run can sometimes mask the Light coming on for a while
If the light Comes on more frequently / regulary Then I'd suggest a Battery change
Ziggy
Thanks Benny 1992 thanked for this post
Meet Bumble-Bee
Old 18-10-2010   #13
ok cheers m8
Old 19-10-2010   #14
Mk2 Punto Sporting 1.2
corky's Avatar
Trader Rating: 1
corky has donated!
New battery pal
corky is offline Reply With Quote Quote
Thread Tools
(G) Active Sport Steering gone really light.. power steering problem? andyleem Punto (Mk2/2b) 6 13-05-2011 11:59
(T) Power Steering Light Flashes & Door Open Light chrisbhull87 Punto (Mk2/2b) 4 23-09-2010 17:53
(T) Engine Management Warning Light Madness! Power Steering light Insanity! Moneypenny Punto (Mk2/2b) 11 12-02-2010 14:10
(T) Power steering light is on SoulPower Punto (Mk2/2b) 19 10-11-2009 18:20
