symonh2000
Member
Hi people.
I went to view a Punto HGT today with a view to buying it. The car had a few issues, although non of which couldn't be easily sorted, however.. There appeared to be an issue with the gearchange.
The gearlever was very stiff, and you had to be very deliberate with gear changed to avoid crunching. Basically I had to concentrate hard to avoid driving like a learner
The seller tried to assure me that all Punto HGT's are like this, but after owning several Alfa's and Fiats I wasn't prepared to believe him.
I have seen threads on here about the linkage becoming stiff, and it being an easy fix, but would this also cause crunching between gears?
The clutch appeared to be disengaging fine by the way.
The car is going to be quite cheap, and I may take a gamble on it if you guys think I should. (I am talking under £1000) I am pretty handly with a spanner.
Cheers,
Simon.
Cheers,
Simon.
