Hi Guys,
I'm after some advice, I have an 1.2 Punto Active Sport 16v (2005).
The problem I'm having is the car seems to have lost power somwhere, general driving I just don't seem to have that 'kick' that it used to have.
The problem is most notable when I start driving in the morning from the engine being cold, and I'm accelerating from 1st gear the car gets to around 2,000 rev's and then I get the feeling its holding back, it feels like it just doesn't want to go above 2,000 rev's although it probably would if I really pushed it.
Now I had a very similar problem last year, Last year the car also lost power, and when accelerating there was no power and when I pushed it a bit the car would misfire, like a juddering effect, the engine warning light would flash and I would have to drop back to first and set off for it get back to normal.
I replaced the spark plugs and the coils and this seem to fix the problem, but this was only 9 months ago if not much less than that.
I have not had the Engine warning light flash, or the skipping effect happen to me since my loss of power this time around, but that may be due to when I can feel it being restrictive, I back off the accelerator instead of pushing it further, If i was to carry on accelerating when It is 'holding back' then I wouldn't be suprised if the same results happened as what used to happen.
As i said, the problem is quite difficult to explain, its one of those things that would be better understood once you have driven the car yourself, but the essential bit is that it has lost power, and general driving around when accelerating its just as if its running on half the power.
Hopefully someone can understand some of what i've described to try and point me in the right direction.
